August 24, 20242 yr Dear all, I just installed headlight on the trs. If i switch on the light its works when running stationary but when gas increases light switches off and goes on when running stationary. This doesnt look normal some one any idea? Regards, Peter
August 24, 20242 yr Is it a Light Emitting Diode or incandescent lamp and guessing it has no battery? If it's LED what does your bike have for rectifying the AC produced by the alternator to DC required by a LED? ... + does the fan work as expected? (the fan also operates on DC) Edited August 24, 20242 yr by lemur
August 24, 20242 yr That's a strange one, I looked at the wiring diagrams and can't see anything that would account for that unless the tail light wires are shorting out or you have a bad ground back to the engine.
August 25, 20242 yr Author 22 hours ago, lemur said: That's a strange one, I looked at the wiring diagrams and can't see anything that would account for that unless the tail light wires are shorting out or you have a bad ground back to the engine. Were can i find wiring diagram so i can check. There is no taillight. Reg. Peter
August 25, 20242 yr 2 hours ago, pdm said: Were can i find wiring diagram so i can check. There is no taillight. Reg. Peter Super easy, search for "TRS motorcycle wiring diagram" and it will be the first image that shows. ... if the headlight is having low power issues the fan should be having problems as well. Edited August 25, 20242 yr by lemur
