Steveyboy Posted April 2, 2025 Report Share Posted April 2, 2025 (edited) Hi, just looking for some inspiration. Took my back wheel off to replace the wheel bearings and noticed the swing arm linkage bearings are absolutely shot and some play in the main bushes too. I've sorted the dog bones out no problem, however the 2 roller bearings in the main arm that the long linkage bolt goes through will just not budge nor will the bushings in the end of the arms. Can someone tell me if there is a step inside the casting or can both bearings and bushes be pushed out from the same side? I've tried a little heat with a warm air gun but no success at the moment. Obviously I don't want to damage anything but just looking for a bit of info Thanks Edited April 2, 2025 by Steveyboy Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted April 3, 2025 Report Share Posted April 3, 2025 On 4/2/2025 at 9:32 PM, Steveyboy said: Hi, just looking for some inspiration. Took my back wheel off to replace the wheel bearings and noticed the swing arm linkage bearings are absolutely shot and some play in the main bushes too. I've sorted the dog bones out no problem, however the 2 roller bearings in the main arm that the long linkage bolt goes through will just not budge nor will the bushings in the end of the arms. Can someone tell me if there is a step inside the casting or can both bearings and bushes be pushed out from the same side? I've tried a little heat with a warm air gun but no success at the moment. Obviously I don't want to damage anything but just looking for a bit of info Thanks A little late perhaps but there is no step , just push/pull them out with heat etc do not hammer on them its not the best of methods. pressing them out hydraulics is the best/easiest way obviously. Quote Link to comment Share on other sites More sharing options...
Steveyboy Posted April 4, 2025 Author Report Share Posted April 4, 2025 11 hours ago, Tr1AL said: A little late perhaps but there is no step , just push/pull them out with heat etc do not hammer on them its not the best of methods. pressing them out hydraulics is the best/easiest way obviously. Thanks for the reply, I'll have another attempt at the weekend. Cheers 👍 1 Quote Link to comment Share on other sites More sharing options...
taffydai Posted 1 hour ago Report Share Posted 1 hour ago how did you get on,was there a step or did they push out the other side ok Quote Link to comment Share on other sites More sharing options...
