April 9, 200620 yr Does anyone know whether the clutch pack from the 06's are a straight fit for earlier machines? I need a new pack for my 04 but i'm sure i read that the 06 clutches were less fussy about the width of the pack and gave less noise. Thanks in advance, Roy.
April 10, 200620 yr Does anyone know whether the clutch pack from the 06's are a straight fit for earlier machines? I need a new pack for my 04 but i'm sure i read that the 06 clutches were less fussy about the width of the pack and gave less noise.Thanks in advance, Roy. <{POST_SNAPBACK}> My mate's just cooked his 280 '05 clutch, he was told that only the 04 style clutch pack was available now..so he ordered it,fitted it and now the clutch is bloody heavy(just like all the pre '05 pros that I have ridden). So build up the muscles in your left hand.
April 10, 200620 yr Author Ah! That's a bugger. I found the quote on the TMX bike test:- "Thicker clutch diaphram spring. The new spring (from 1.5mm to 1.7mm) allows more wear tolerance of the clutch plates without it slipping. Clutch pack height is now not quite as important as before." Waiting to hear back from GG UK as to what they recommend. Cheers, Roy.
April 10, 200620 yr Author Just heard back from GG UK and they are only supplied with one type now so that makes it a bit easier. Will compare part numbers when it arrives if anyone is interested.
April 10, 200620 yr Hmmm maybe thats why my clutch is very heavy..because they put a 04 clutch in mine before i got it. Cant you get an 06 or 05 clutch then ?
April 10, 200620 yr i replaced all of the plates in my 05 gasgas clutch and it was at first heavy but this was due to air in the system, and after i bled it it was fine
April 10, 200620 yr Air in the system makes it a lot different to what a heavy clutch is i would say it doesnt work properly with air in the system.
April 10, 200620 yr Author Hi Lew, GGUK didn't say what year the clutch packs were from just that they were only being sent (from Spain i presume) one type at present. I'll see if i can work out the year when it arrives. Roy.
April 11, 200620 yr Ok cheers mate , you would have thought though they would have spares for 05 and 06 really.
April 11, 200620 yr I have just orded at new clutch for my TXT280 from 05. They are sending me a 06 clutch. The 06 clutch have the same spairpart number as the 05!
April 12, 200620 yr Extreme thirsty Well this is my first change of a clutch on a bike with a hydralic activated clutch. The local dealer told me that the water need to get of and that I don't need to take the clutch fluid out. My bike is a TXT280 from 05. So I don't need to empty the bike for water and clutch oil? Reading on this topic it seems that everybody has problems with the clutch fluid when they change the clutch... why? if they don't need to empty the bike for clutch fluid. Edited April 12, 200620 yr by Thomas_trial
