Fork Oil Level
Seabag
I'm new here and have just bought a used 2019 Vertigo Combat Vertical 250cc.
I'm about to change the oil in both front forks, but I'm a bit unsure about the correct oil level. In the service manual for the bike, it says the oil level should be 130 mm in both forks. However, in the service manual for the forks — which are Tech Suspension — it states that the level should be 130 mm in the left fork and 75 mm in the right.
Which one should I trust?
Short answer: probably Tech.
The left side has the wire spring, so a lower fluid level tends to compensate and gives a similar air chamber volume as a higher level without a spring.
But ultimately, those numbers are just a starting point.  The fluid level affects the bottoming behavior.  Different riders may require/prefer different settings.
It's easier to add oil (using a syringe) than to remove it.
More info here: https://www.electricmotiontech.com/home/em-epure-race/mechanicals/tech-39mm-forks
