fiddler2 Posted August 8, 2025 Report Share Posted August 8, 2025 Need to do engine inspection .. advice for splitting crank case . What needs to be removed ? Clutch ,crank weight . Mag off, oil seal carrier . Kick and gear off already hot air gun help? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 9, 2025 Report Share Posted August 9, 2025 20 hours ago, fiddler2 said: Need to do engine inspection .. advice for splitting crank case . What needs to be removed ? Clutch ,crank weight . Mag off, oil seal carrier . Kick and gear off already hot air gun help? Don't normally need hot air gun for Bultaco unless someone has used sealant on the centre gasket. gearbox output sprocket and seal spacer cylinder shift drum external mechanism shift drum indexing plunger all the nuts and screws - one screw is tricky to see 1 Quote Link to comment Share on other sites More sharing options...
bullylover Posted August 9, 2025 Report Share Posted August 9, 2025 You also need to remove the primary drive and the clutch. Basically everything on the primary side. David forgot to mention that. Don`t lose the small washer on the kickstart gear inside the center cases. 1 Quote Link to comment Share on other sites More sharing options...
fiddler2 Posted August 27, 2025 Author Report Share Posted August 27, 2025 All back together . Will put back in frame and hope for a start . Quote Link to comment Share on other sites More sharing options...
