ManuMotion Posted 8 hours ago Report Share Posted 8 hours ago Hey Guys, In the past few days, my Electric Motion Trial has occasionally cut the throttle while riding. Now it doesn’t work at all. The kill switch still lights up, but there is no startup sound and the map switch doesn’t light up anymore. The battery provides about 50V and the battery relay clicks as expected. I also tried bypassing the kill switch, but it didn’t help. thanks! Quote Link to comment Share on other sites More sharing options...
konrad Posted 7 hours ago Report Share Posted 7 hours ago Based on your prior description, I assumed you had the 2019 model year. That is the first year EM used the siliXcon controller. The wiring diagram will be very similar to the Epure bikes: https://www.electricmotiontech.com/home/em-epure-race/wiring-diagram No startup tones would seem to indicate the controller is not being enabled. Did you bypass your "Security Magnet" (kill switch) as I describe here: https://www.electricmotiontech.com/home/em-epure-race/wiring-diagram#h.fogcawtque8h Quote Link to comment Share on other sites More sharing options...
ManuMotion Posted 7 hours ago Author Report Share Posted 7 hours ago 27 minutes ago, konrad said: Based on your prior description, I assumed you had the 2019 model year. That is the first year EM used the siliXcon controller. The wiring diagram will be very similar to the Epure bikes: https://www.electricmotiontech.com/home/em-epure-race/wiring-diagram No startup tones would seem to indicate the controller is not being enabled. Did you bypass your "Security Magnet" (kill switch) as I describe here: https://www.electricmotiontech.com/home/em-epure-race/wiring-diagram#h.fogcawtque8h Yes, it already has the Silixcon controller. I also bypassed the kill switch following your very good instructions, but unfortunately without success. Quote Link to comment Share on other sites More sharing options...
konrad Posted 3 hours ago Report Share Posted 3 hours ago It's possible there is a fault in your wiring harness and the enable signal is not making its way back to the controller. There's good documentation here: https://docs.silixcon.com/docs/hw/esc/sc1/Wiring and here: https://docs.silixcon.com/docs/hw/esc/sc1/IO Bear in mind that the EM controller does not use the flip-flop function for enable. There must be constant battery voltage on the controller's "POWER" input to allow it to operate. Be mindful that there is a non-replaceable fuse inside the controller. Don't short the "KEY" pin to ground (that's why an external resistor is recommended for current limiting). Quote Link to comment Share on other sites More sharing options...
