HOOKYH Posted October 13, 2025 Report Share Posted October 13, 2025 (edited) Hi, have quite a loud whining noise that comes and goes with clutch engagement. When its disengaged there's no noise at all. Had the clutch apart and all seems fine, did wonder if it was the basket bearing but there's no play. Haven't changed oil type (nano trans) but has fresh oil. Any suggestions welcomed. While im here does anybody have any tips for putting the clutch cover o ring in place? Has literally just taken me longer to put the cover back on than take the clutch to bits, inspect it, clean it and reassemble it! Edit: 2012 250 2t Edited October 13, 2025 by HOOKYH Forgot to say what bike Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted October 14, 2025 Report Share Posted October 14, 2025 On 10/13/2025 at 3:07 PM, HOOKYH said: Hi, have quite a loud whining noise that comes and goes with clutch engagement. When its disengaged there's no noise at all. Had the clutch apart and all seems fine, did wonder if it was the basket bearing but there's no play. Haven't changed oil type (nano trans) but has fresh oil. Any suggestions welcomed. While im here does anybody have any tips for putting the clutch cover o ring in place? Has literally just taken me longer to put the cover back on than take the clutch to bits, inspect it, clean it and reassemble it! Edit: 2012 250 2t Use silicone grease on O rings to make them stick in the grooves of casings during assembly. whining noise may be the primary gear with the clutch meshing , Check the nut that holds the clutch basket/bell on is tight. 1 Quote Link to comment Share on other sites More sharing options...
cello Posted November 23, 2025 Report Share Posted November 23, 2025 I used some vasoline but crucially lay the bike on its side so gravity is assisting the rubber o ring from poping out . Quote Link to comment Share on other sites More sharing options...
