Metchosinjoe Posted 1 hour ago Report Share Posted 1 hour ago Hey first post looking for some guidance on my recently acquired 06 rev 3 had some wiring issues which lead to a not running issue which lead to me kick starting it with a couple loose bolts and cracking the inner clutch cover. replaced the cover got it all together and now have no clutch disengagement. when I pulled the inner cover I pulled the shift shaft out a bit before I noticed. i pushed it back in and seemed fine. Im very mechanically inclined just new to trials bikes does the shift shaft go into the slave and did I make a boo boo and pop the slave out? Quote Link to comment Share on other sites More sharing options...
