06 beta rev 3
Metchosinjoe
Hey first post
looking for some guidance on my recently acquired 06 rev 3
had some wiring issues which lead to a not running issue which lead to me kick starting it with a couple loose bolts and cracking the inner clutch cover.
replaced the cover got it all together and now have no clutch disengagement.
when I pulled the inner cover I pulled the shift shaft out a bit before I noticed.
i pushed it back in and seemed fine. Im very mechanically inclined just new to trials bikes
does the shift shaft go into the slave and did I make a boo boo and pop the slave out?
Possibly air got into the clutch hydraulics while it was lying down.
Alternatively, if you pulled the clutch or pressure plate off, you may have let the clutch pushrod ball fall out and not notice it.
I doubt the shift shaft has anything to do with it.
