October 2Oct 2 Author I'm planning to adapt this wheel to an AJP hub or mount the rim on the original hub to convert it to tubeless, like on the factory bike. The hardest part will be finding spokes at an affordable price. Alternatively, I could laser-clean the spokes and repaint them with Sprido epoxy. we'll see.
October 10Oct 10 Author I have a few parts... I chose a polished AJP hub, GasGas type (for the inner diameter of the sprocket). Other advantages compared to the red Montesa 311 AJP hub: - both bearings are 6004 2RS - the center spacer is aluminum. This is simpler and lighter. I stripped the spokes to repaint them with 1K satin gray epoxy. Great! Final result: A clean wheel, lighter than the original, and tubeless! Now I just need to finalize the assembly on the Aprilia. Outer spacers and hardware. I still have a few ideas to get even more enjoyment out of this motorcycle. Edited October 10Oct 10 by ahell
October 11Oct 11 Author Correctly position the disc in the brake caliper using a suitable spacer. Comparative measurement of the rim's position relative to the original wheel. (I shifted it all the way to the left to achieve the 60mm dimension.) The spacer on the sprocket side still needs to be made to match the original wheel's dimensions. All that remains is to adjust the spoke tension and mount a tire. Edited October 11Oct 11 by ahell
October 12Oct 12 Author To make a complete set of wheels.Same base as the rear, Akront rim on a lightweight AJP hub with 36 spokes.After cleaning the hub, a pair of new bearings.The spokes and nipples are new (A joy to assemble!)And finally, a lightweight rotor.
October 30Oct 30 Author Titanium head bolt. (M14 x 1.50)Next titanium parts are coming ... Edited Wednesday at 12:23 PM2 days by ahell
Wednesday at 12:21 PM2 days Author While waiting for the titanium screws, new for the Climber.The original unrestored shock absorber works without leakage but is slow.Rather than restoring it, I'm going to test an assembly from a new aluminum Sachs.Shorter than 5 mm, I will raise the fork in its tees to keep the original plate.Lowering the center of gravity can be a plus and this generation of motorcycle had a good ground clearance. To see, otherwise I will make a custom-bound screed.The weight when it drops by more than 1kg.Good for the weight and the center of gravity all this!
6 hours ago6 hr Author -4kg 🤩Way better shock reboundlower gravity center (less weight and shorter suspensions)Better front brake : new front wheel with AJP hub, NG brake disc and Freno blue pads
2 hours ago2 hr Author AJP hub 36x SS spokesAkront light version rimNG SS lighter discFreno padsErgal front axle and machined gripster nut
