Aprilia Climber 280 1993
The second mudguard with decals.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20260923
I'm planning to adapt this wheel to an AJP hub or mount the rim on the original hub to convert it to tubeless, like on the factory bike. The hardest part will be finding spokes at an affordable price.
Alternatively, I could laser-clean the spokes and repaint them with Sprido epoxy. we'll see.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261012
I have a few parts...
I chose a polished AJP hub, GasGas type (for the inner diameter of the sprocket). Other advantages compared to the red Montesa 311 AJP hub:
- both bearings are 6004 2RS
- the center spacer is aluminum.
This is simpler and lighter.
I stripped the spokes to repaint them with 1K satin gray epoxy. Great!
Final result:
A clean wheel, lighter than the original, and tubeless!
Now I just need to finalize the assembly on the Aprilia.
Outer spacers and hardware.
I still have a few ideas to get even more enjoyment out of this motorcycle.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261024
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261026
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261027
Edited by ahell
Correctly position the disc in the brake caliper using a suitable spacer.
Comparative measurement of the rim's position relative to the original wheel. (I shifted it all the way to the left to achieve the 60mm dimension.)
The spacer on the sprocket side still needs to be made to match the original wheel's dimensions.
All that remains is to adjust the spoke tension and mount a tire.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261028
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261029
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261030
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261031
Edited by ahell
To make a complete set of wheels.
Same base as the rear, Akront rim on a lightweight AJP hub with 36 spokes.
After cleaning the hub, a pair of new bearings.
The spokes and nipples are new (A joy to assemble!)
And finally, a lightweight rotor.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261032
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261033
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261034
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261035
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261036
  • 3 weeks later...
Titanium head bolt. (M14 x 1.50)
Next titanium parts are coming ...
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 87006511
Edited by ahell
While waiting for the titanium screws, new for the Climber.
The original unrestored shock absorber works without leakage but is slow.
Rather than restoring it, I'm going to test an assembly from a new aluminum Sachs.
Shorter than 5 mm, I will raise the fork in its tees to keep the original plate.
Lowering the center of gravity can be a plus and this generation of motorcycle had a good ground clearance. To see, otherwise I will make a custom-bound screed.
The weight when it drops by more than 1kg.
Good for the weight and the center of gravity all this!
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 89045810
-4kg 🤩
Way better shock rebound
lower gravity center (less weight and shorter suspensions)
Better front brake : new front wheel with AJP hub, NG brake disc and Freno blue pads
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 86205410
AJP hub 36x SS spokes
Akront light version rim
NG SS lighter disc
Freno pads
Ergal front axle and machined gripster nut
Peut être une image de vélo
Peut être une image de moto et moto tout terrain
Titanium parts : triple clamps, suspension linkage and more (-270grs)
Scorpa easy 1996 brand new rear disc
Beautiful Régina lighter chain
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 89474410
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 89469010
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 89697810
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 89615710
Titanium rear axle (110gr less)
2x titanium bolt -25gr
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261113
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261114
Edited by ahell
7075 alloy make a big difference.
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261115
Aprilia Climber 1993 Tommy Ahvala replica - Page 2 20261116
