Nifty Little Gadget For Measuring Oil
http://www.fearing.co.uk/healthcare.htm#drs25
Just used it to dose the 520mm needed for the g/box on my Montesa, took 60 seconds and no spillage. I use it for 2 stroke oil as well because it measures down to 5ml. Unorthodox but handy <_<
Are you on about that sureshot thing?
I just use a big syringe that i got given from a hosiptal and a rubber pipe, use two
-one for GB
-one for two stroke
Surely the cheapest option ?
But still an interresting find you've got there
-one for GB
-one for two stroke
Yep, the Sure Shot. I like it because you just dump the pipe in the bottle and it refills itself, just keep pumping the oil in. Bought it originally when I wanted a convenient way of doing the premix a road legal KX500 (which never actually made it to the road)
Edited by Zanx
i use to use a shringe for oil it was great until the oil affected the rubber seal in the bottom of the shringe then the rubber droped off then i had to use a bung to stop the oil coming out the best thing to use is an old medcine bottle which holds just enough oil to mix your 2stroke mix but he good luck
