Which Oil
scoobie
Hi,
Just bought a 2000 Rev 3 270 which has just had a complete engine rebuild. Should I use synthetic oil for the first couple of hours? If yes which type and at what mixture? I've got Plutline that I use on my KTM, is that OK?
After the first couple of hours what oil do you recommend then, and at what mixture?
Also what gear box oild does anyone recommend?
Finally, what's the torque setting on the gearbox drain bolt?
Sorry for all the questions.
Cheers,
Hi,
Thanks for the reply. Pardon my ignorance but does 75:1 mean 75ml of oil to 1 litre of fuel, therefore 375ml to 5 litres? Or 1ml of oil for every 75ml of fuel?
Cheers,
