First Beta - Maintenance
Guest stixnstonesbrokemybones
Hi, coming back to bikes/ trials after a long long break, I've bought an 08 Beta 250. Would any of you be able to lend me first hand experience or tips for the sucessfull cleaning/ maintenance - all the common sense stuff that's never in the manuals. For the first few months I'll be in thick clay/ mud stuff on the Chilterns. Shouldn't see too much sand unless I go down Hants way, and I'm staying well clear of rock for a while!
Also any mods/ add ons recommended.
Cheers
Welcome back
I would re loctite the bolts at the top of the front frame stays near the top of the rad,the rear bashplate bolts and disc bolts as on some bikes these are prone to coming loose.
Also if you plan to do alot of riding in the wet I would strip the electrics off the bike an replace with a yam style kill button and if you ride alot in clayey mud space the front mudguardup by 10mm.
Apart from checking allthe bolts for tightness I dont think there is much else out of the ordinary that you need to worry about as long as the Keihin carb behaves better than the Mikuni fitted in the past
have fun
Every Outing
First, give the bu&&er a good clean, don't blast bearing sites with the power hose, dry it off.
Check all bolts for tightness or take em all out and loctite the bu&&ers in.
Take off timing side cover dry it out give it a blast with WD40
Take bolt off bottom of float chamber on Carb empty it out and make sure there are no deposits in the bottom, if so clean em out
Clean Air Filter
Give chain a good soak in deisel, wire brush the worst of the cr@p off, wash it to get the rest off it put it back on the bike and give it a blast with chain lube (the better ones disperse any water left between plates rollers etc.
Check all breathers/fuel hoses for cracks, blockages, splits etc replace as necessary
Every 12 - 15 hours use
All of the above PLUS
Change Gearbox oil (use 500cc Dextron ATF)
Check for play in bearings (Wheels, suspension mounts etc etc) replace as necessary
Check for play at head stock, re-adjust if necessary
Check brake calipers, clean them make sure pads aren't lipped or overly worn replace as necessary
Strip Carb blow through jets etc with an airline or compressed air canister
Check play in Chain adjust as necessary, check wear on sprockets replace as necessary
That's the routine stuff I do plus dealing with any other issues as they happen, hope this helps
Edited by Slapshot 3
