JSE, on Oct 16 2008, 10:11 PM, said:
Assuming all other things are good (connections tight, including the plug cap screwed on well, a good plug gapped to .024", .6mm, absolutely fresh premix etc) you might try a larger "starter jet", which is the jet on the brass tower that feeds the starter circuit. Some come with a #60 and they seem to work better with a #80 (or you can drill out the jet with a .031" drill). Be sure to NOT open the throttle when kicking it over as that defeats the starting enrichening device. When kicking it, be sure to engage the racheting mechanism easy before putting weight on the lever and the parts will last as long as you have the bike. It's the slamming down on the kickstart lever that breaks parts.
I'm guessing you are opening the throttle like a four-stroke carb when you kick it cold.
Jon
Jon, here in the uk we don't mess with jets too much, think the gassers are pretty much spot on for jetting.
factory kev and shirty will sort this problem if it is one, but my first trip would be to the dealer.
However, assuming you know how the choke works and you have new clean fresh petrol and have a good spark then first check float level then the banjo filter. If not it may be the choke.
