Climber 240 Spark Plug Problem
4 replies to this topic
#1 simonhod
    New Member
  • Members
  • Pip
  • 4 posts
  • Bike:aprilia climber 240
Posted 22 March 2009 - 10:05 PM
i have a aprilia climber 240 have had it for about 5 months now and had no problems wth it till now. The bike was running fine then it just cut out took plug out to see if it was sparking and no spark so i changed the plug and it worked for about a hour and then the same no spark with new plug so i got another plug and that is sparking. any one know what could be causeing this to happen
also dose anyone know what spark plug should be in a climber 240.........................
thanks simon
#2 lineaway
    Advanced Member
  • Members
  • PipPipPip
  • 342 posts
Posted 23 March 2009 - 12:15 AM
I always used NGK. stock should have been bp7es, but we always ran bp5es at altidude. You might remove the flywheel cover.(right hand side) And check too see if the flywheel has any play. The main bearings where always a culprit of timing issues.
#3 The Batt
    New Member
  • Members
  • Pip
  • 3 posts
  • Bike:06 Sherco 290
Posted 23 March 2009 - 01:00 PM
Have ridden a few of these in my time.
The problem is if you knock the fly wheel cover on a rock, it moves & causes the stator to rub on the fly wheel. This over heats the stator & damages the windings.
So you have a spark until it heats up, then loses the spark. Only cure is to replace the stator or have it repaired.
Hope this helps you.
#4 Stork955
    Advanced Member
  • Members
  • PipPipPip
  • 564 posts
  • Bike:Beta Evo 250 2010
  • Club:Tasmanian Motorcycle Trials Club
Posted 23 March 2009 - 08:13 PM
What colour did the plugs have when they came out? If they are wet and black looking, there is a fouling issue which may be caused by Air filter or Carb. Always make sure you are using the correct plug, 2 strokes last seconds with the wrong one fitted! It is really important. Check it out and let us know.
Cheers,
Stork
#5 steve666
    New Member
  • Members
  • Pip
  • 8 posts
  • Bike:beta rev3
  • Club:Earl Shilton
Posted 11 April 2009 - 08:21 PM
it sounds like the stator requires a rewind , i had this problem check out the other threads on bike not starting etc (the cost of a rewind is about £75 )
