Trials Central: Rattle From The Top End Of My 4rt What Could It Be? - Trials Central
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Rattle From The Top End Of My 4rt What Could It Be? Rate Topic: -----
#1 User is offline   mark1984
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:montesa 4rt
  Posted 08 June 2010 - 06:18 PM
i have a slight rattle from the top of the barel and it gets quicker when i rev it could it be the tappets needing adjusted? can any one tell me a easy way to do this or some tips on doing it? i.e how do i know that it is at the top end of the compresion stroke? how can i most accuratly adjust them? any help please
#2 User is offline   GII
  • Advanced Member
  • Group: Site Supporter
  • Bike:4RT
  • Club:South Shields DMC
Posted 08 June 2010 - 10:59 PM
The manual covers this (and everything else) very comprehensively.
Take off the valve covers and the oil fill cap
Rotate the crankshaft 'till the T mark on the flywheel lines up with the reference mark in the oil fill hole
Check that the engine is on its compression stroke i.e. both rockers are loose, if not, rotate crankshaft through 360º
use bent feeler gauges to set valve clearances, inlet 5 thou, exhaust 12 thou .
If you don't understand this, pay someone who does to do it, it'll be cheaper in the long run.
I've had 2 Montesa 4RTs, the first needed the exhaust rocker slackening off a little after 2 years (still in tolerance but had tightened slightly), the second one is just over a year old (60ish trials) and needs no adjustment yet.
Gordon
#3 User is offline   mark1984
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:montesa 4rt
Posted 09 June 2010 - 06:54 AM
i have a user maual but the settings are difrent to 5 and 12 they are more like 12 inlets and 20 exhaust would that be rite for a 2006? is it difrent on later models?
#4 User is offline   munch
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Bike:M.SPORT 4RT
  • Club:three shires
Posted 09 June 2010 - 10:01 AM
tappets are the same 05>10
4rt quality worth waiting for !
#5 User is offline   GII
  • Advanced Member
  • Bike:4RT
Posted 10 June 2010 - 11:06 PM
It seems you don't understand the difference between thousandths of an inch and hundredths of a millimetre.
Since you say you have the manual which I know explains the setting sequence in simple terms and with photographs, I repeat:
Quote
Gordon
#6 User is offline   andyevans
  • Member
  • PipPip
  • Group: Members
  • Bike:montesa
  • Club:oswestry&dmc
Posted 12 June 2010 - 09:01 AM
the guy is ignorant , he cant be bothered to reply to most things !
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
