jtr 370 cylinder head skimming
9 replies to this topic
#1 nath15804
    Advanced Member
  • Members
  • PipPipPip
  • 109 posts
  • Bike:sherco 290
  • Club:barnsley, huddesfield
Posted 11 October 2010 - 06:37 PM
Hi,
i have recently been told ( by a mechanic) that my cylinder head on my gasgas jtr370 needs skimming but hes not sure whether you can do it on these models because of a groove or something, can anyone shed any light on this situation, i would be very greatful.
nath
#2 GII
    Advanced Member
  • Site Supporter
  • 287 posts
  • Bike:4RT
  • Club:South Shields DMC
Posted 11 October 2010 - 07:21 PM
How distorted is it? If it's not much you could try lapping it flat with grinding paste on a piece of glass
On a bike of that age and value, I'd be more inclined to try a couple of new o rings and a healthy application of good quality silicone before I paid someone to skim it.
Gordon
#3 nath15804
    Advanced Member
  • Members
  • PipPipPip
  • 109 posts
  • Bike:sherco 290
Posted 11 October 2010 - 07:40 PM
Cheers, what do ye mean by lapping it with the glass?
#4 nath15804
    Advanced Member
  • Members
  • PipPipPip
  • 109 posts
  • Bike:sherco 290
Posted 11 October 2010 - 07:52 PM
He has said it is a tenth of a mill out by the way
#5 Monty_Jon
    Advanced Member
  • Members
  • PipPipPip
  • 495 posts
  • Bike:BSA C15 / Bultaco
  • Club:Stratford-upon-Avon
Posted 11 October 2010 - 08:08 PM
Place the head on a piece of Very fine wet & dry on top of a sheet of thick glass or a surface table
Move the head in a figure of 8 a few time then rotate the head 90° and do the same several times (don’t remove to much metal!)
#6 Monty_Jon
    Advanced Member
  • Members
  • PipPipPip
  • 495 posts
Posted 11 October 2010 - 08:12 PM
0.10mm shouldn't cause any problems anyway, the head bolts will pull that flat! :thumbup:
Edited by Monty_Jon, 11 October 2010 - 08:36 PM.
#7 nath15804
    Advanced Member
  • Members
  • PipPipPip
  • 109 posts
  • Bike:sherco 290
Posted 11 October 2010 - 08:13 PM
ok cheers, and is a tenth of a mill a lot when it comes to cylinder heads?
#8 Monty_Jon
    Advanced Member
  • Members
  • PipPipPip
  • 495 posts
Posted 11 October 2010 - 08:44 PM
0.10mm is nothing on a single, tighten it properly with new “O” rings as GII says it should sort it out :thumbup:
Edited by Monty_Jon, 11 October 2010 - 08:45 PM.
#9 nath15804
    Advanced Member
  • Members
  • PipPipPip
  • 109 posts
  • Bike:sherco 290
Posted 11 October 2010 - 10:14 PM
cheers, the guy said once he had put it bk together water was coming out, could this be because he hasnt tightened the bolts enough? how tight should they be? anyone no the figure?
#10 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,025 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 12 October 2010 - 01:45 AM
Tape the sheet (I use 280 or 320 grit) to the glass with some masking tape to make it easier and use a little water on the paper. As you only need to take off .004" total the lapping will remove about .002" from each side to square it up, so you should be o.k. Be sure to grease the o-rings before installing them so they can settle in the groove.
Jon
