As i remember the G/box is 75w (can anyone confirm)
The power to the sender is not present I think its done with a resistor? it all has to be wired right and the unit in the head can pack up have you tried joing the wires up if it all fails try Martin @ MRS for some advice he helped me when mine had this prob
I do have some PDF's if they are any good for you email me and ill send them
Thanks for that.
I took the fan motor off and tried it on a battery. It was dead so i bought a used one so i'll bung that on later but i dont expect that to entirely solve the problem as i tested the wires to it while the bikes running and there was no live to it. Is this something to do with the little black box mounted to the fan housing (i havent tested all the wires to it for a live yet).
My email is madcr500@aol.com. Those pdf's would be really useful to me if you dont mind sending them.
75w sounds heavy. I have a cr500 motard, the manual for that says to use 80w only when running in (from the factory) then to switch to 10/40. can anyone confirm for sure which oil i use before i change it?
Thanks again for the help, i appreciate i am a new member and havent contributed to the site yet so thanks.
I am the now the proud owner of a 97 easy 250. it needs some TLC so i have a few questions.
What oil should i be using in the gearbox?
Can anyone point me to a wiring diagram for this model? the loom has been messed with and i dont seem to be getting any power to the temp sender (or fan obviously)
Thank you in advance for any help. i'm sure i'll have more questions as i go along.
Easy 250 Scorpa - Help
in Scorpa
Thanks for that.
Marcus
