Ty250r
pat
Hi,
Searching for a work shop in the UK who offers the same knowlegde and machining as B&J Racing US.
Need to optimise my squish band and port the cylinder.
Im even interested of data for correct squish and head cc, so I can send it to a work shop closer to home.
About porting, guess only encreasing width gives benefits.
My TY250R-84 set up
Engine
Boyesen #663
Sammy pipe
Tot rebuilt engine
Pilot 44(have tested 35 and 40, but RON105 dont cover the pinging)The marks on ign.plate/crank case matches.
Main 122.5(mikuni)
Extended clutch lever
Twin air, same as TYZ
Single grade W30
Synt 2-s, 1.4%
Chassie
Extended shock(no leaking) and encreased pre-load set up
GasGas-04 front wheel
Stainless for rear brake (instead of the stupid wire)
Chain wheels from B&C
Lovely Michelin
Thinking of:
Engine
Dismantle the fly wheel weight, running with clutch all the time any way
Rebore and port cyl
Machining squish
Wiseco for IT
Mikuni VM28
Alloy repackable middle- and end silencer
Maybe an TYZ-like pipe
Alloy kick start
Chassie
New front end springs, fresh stock Nm/mm
Lower the foot pegs 25mm and modern wide
New rear wheel, unbelivable the hub has been welded before I bought it, could coop with a used stock hub
A smaller tank unit
Maybe lower the air box
Mini clutch lever
Edited by Pat
Hi Pat,
The exhaust port needs raising quite a lot and widening a touch, I have the required dims somewhere which I'll try and dig out, the later pistons also have shaped crowns. I think I took about about 10mm off the flywheel, again I'd have to check. The inlet tract/manifold was shortened by apprx 12mm which then moves the carb and airbox down and forward, this makes BIG difference especially bottom end. Finally I advanced the ignition 3-4mm. You end up with a quieter, smoother and more poky motor which is far usable in sections. There was a brand new ally kickstart on ebay this week .
I'll try and find all the Dims and PM you with them
