Fantic 303 Maintenance
Is there anyone who can help with parts and diagrams/instructions for replacement of front fork seals and rear suspension bushes. I am located in Perth Western Australia. I think that it is 1988/89 model, but I am not sure. Any help/suggestions would be greatly appreciated.
Give bill pye at frankfield garage a ring,i got all my 303 parts from him. He is in middlesborough (uk) tel 01642722378 he sends fantic parts all round the world.
If yours is the blue-red 303 of 1987, or the Series2 blue-yellow model of 1988 then it will have a wide wishbone linkage rather than the more modern tri-point central block of the fluoro orange 89-305 and later models.
The 303 featured a tricky steel bush inside a wear sleeve through the side of the swingarm ..and riders whine about maintainig todays linkages!!
Let me know which and I will e-mail the rear suspension parts page.
It might be worth contacting Steve Goode motorcycles on(u.k)01938 850544.
A few year ago i had an '86 progress (first of the mono's),the rear linkage bearings were knackered and Steve supplied a set of inner and outer bushes for cheap,but more interestingly he also supplied a new set of linkage pins which were drilled and had grease nipples fitted.
I would imagine the bearings and pins would be the same as the 303 because manufactuers didn't change things for fun in those days!.
Anyway good luck, cheers
Spencey.
It's the Series 2 Blue/Yellow. If anyone has any other parts diagrams it would be helpful.
