reddawgst Posted November 2, 2006 Report Share Posted November 2, 2006 I have Montesa Cota 311. Went to change transmission oil and cannot find the drain plug. Removing case bolt (like I do on my 315R) has no effect (no oil comes out). Any suggestions gratefully accepted. Thanks Link to comment Share on other sites More sharing options...
fergush Posted November 2, 2006 Report Share Posted November 2, 2006 Either remove sump guard to get access to drain plug; or remove clutch cover and tip the bike on its side. Neither option is ideal, but there you go! Link to comment Share on other sites More sharing options...
reddawgst Posted November 2, 2006 Author Report Share Posted November 2, 2006 Thanks for the "tip" (pardon the pun). Do you happen to know how much oil to fill it back up? Thanks again Link to comment Share on other sites More sharing options...
canine Posted November 2, 2006 Report Share Posted November 2, 2006 There is a drain plug underneath and the sump gaurd has a hole in it for you to drain the oil watch when tightening it back up as they some times strip the threads the top up bit is beside the kickstart and i think it takes 500ml although i run 800ml in mine i also use auto transmission fluid as i find it helps reduce the clutch drag Link to comment Share on other sites More sharing options...
reddawgst Posted November 3, 2006 Author Report Share Posted November 3, 2006 I know the newer gas gasers use atf, I didn't know any montesa riders did too. Do you know what the recommended oil is? I switched to PJ1 Clutch tuner on my 315R with terrific results. It is about 75 weight I think Link to comment Share on other sites More sharing options...
canine Posted November 4, 2006 Report Share Posted November 4, 2006 I'm not sure what the reccomended oil is, did you get the oil changed ok? Link to comment Share on other sites More sharing options...
reddawgst Posted November 6, 2006 Author Report Share Posted November 6, 2006 Yes, Thanks. After I pulled the clutch cover off and tipped the bike on its side I discovered the hole in the bash plate that I couldn't find before. I guess I wasn't expecting it to be so far forward. I put the PJ1 clutch tuner in (500ml). I told Brad to make sure he put the brakes on before dropping it into first, but absolutely NO lurch when he did, just snicked into gear. Now it shifts great. We changed the plug and it fires right up now, he was very happy with the improvements. We had two events this weeked, he got a second in his class, and I got a 2nd in my my class, followed by another 2nd today. Very nice weekend. Thanks for your help!! Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
