November 6, 200620 yr The solution to level 4 is (partially) embedded in the main image. If you copy and paste the image into Photoshop and fiddle with the gamma values, you should be able to see the text. There's probably an easier way of doing it but that's what I did. For level 5 you have to extract the image metadata. That's when I got annoyed and gave up. Seriously, life's too short Fun if you're the sort of person who does the Times crossword in 5 minutes though (not me!) Edited November 6, 200620 yr by neonsurge
November 7, 200620 yr Fun if you're the sort of person who does the Times crossword in 5 minutes though (not me!) It takes you as long as 5 minutes.........It's only the times Edited November 7, 200620 yr by Slapshot 3
