November 6, 200620 yr Hi, Wonder if anyone can help, just bought a rough seeley to do up.Thing is it ticks over lovely but when i open the throttle up it tends to die, ive lifted the needle, clean the carb, i know its running lean as it gets hot quick.Anyone got any ideas. Also i was given the original Seeley owners manual if anyone needs a copied version and a clip from TMX advertising the seeley.
November 6, 200620 yr Yes I'd like one too. Your problem almost has to be fuel. Try blowing into your tank vent and forcing a little gas past the needle and seat. See if it will rev out.
November 6, 200620 yr Author Email me ,I ll scan it and send you it. davy@barron63.wanadoo.co.uk , mark subject seeley.
November 6, 200620 yr How rough is the Seeley? Does any one know if the bloke who was going to manufacture some silencers did them in the end?
November 7, 200620 yr Author Hi got the bike to rev out, followed all your instruction, Put Needle to where you said Lifted Fuel Level, runs a treat now! Thanks for your Help
