March 18, 200422 yr Hi guys the question i have to ask is: is there anyway to tell if a preious Montesa(2000) model has been rekitted to look like a 2001 same for the 2002 can you tell the difference between a 2001/2002 just by looking at it or do you just have to go by what the seller says?? cheers Chris
March 18, 200422 yr REV'er, the only real visual difference between a 2000 and a 2001 (excluding plastics and decals) is that rear brake caliper is exposed, where as 2001 onwards they are neatly tucked-in behind the swing-arm, the front brake is a two-pot and on the 2001 onwards is a four-pot. I believe other than that it's all down to engine spec and frame geometry. Gaff. Edited March 18, 200422 yr by Gaff
March 18, 200422 yr there is a way by the engine / frame number. sandifords will tell you if you call them!
