December 24, 200619 yr i found an entire clutch assembly from a 74 ty. the fellow thinks it would work in an 84. any thoughts?
December 25, 200619 yr My guess is that it is not likely to be interchangable. The TY250N-R motor is a different series to the motor used in the Twinshock TY250A-E.
December 25, 200619 yr no it wont fit. the ty twinshocks had a dt250/400 clutch. The monos were from an sr! Can I buy iz for my twinshock???? lee
December 25, 200619 yr Author e bay # 260066566400 it was an e bay item in washington state. the auction is over but no one bid. if you look at his other items you can" ask seller question". thanks jer
