September 1, 200719 yr I left my bike out in the rain for an hour now it wont start any ideas It was going fine until then. Tried spraying it with WD but no Ideas dried it out in the garage.
September 5, 200719 yr You probably have water in the kill button. Remove the button from the bars, dry it out and replace. I f not, it could be something more sinister like a bared wire shorting to ground with the rain water, under the headstock area. Bye, PeterB.
September 6, 200719 yr I left my bike out in the rain for an hour now it wont start any ideas It was going fine until then. Tried spraying itwith WD but no Ideas dried it out in the garage. Look in your airbox and see if your filter is sitting in a pool of water. I have a working drain now after the same thing happened to me. Edited September 6, 200719 yr by cdn280
