November 2, 200719 yr Like it! I work with a few "Makem Taks" so all I have to do now is memorise a few verses over the weekend so I can sing it to them next week. Edited November 2, 200719 yr by GWREV3
November 3, 200719 yr Derby game next week...I do hope Kenwyn Jones is not playing I hope you both lose!!!!!!
November 3, 200719 yr I do hope you have problems fitting those bearings Wayne mrs baldilocks is a born and bread mackem, I dread to think where she'll put your bearings. seals leaking will be the least of your worries !!! AND just in , from Mrs Baldilocks, Portsmouth 4 Toon 1 !! Edited November 3, 200719 yr by Baldilocks
November 3, 200719 yr Author I do hope you have problems fitting those bearings Wayne.....mrs baldilocks is a born and bread mackem, AND just in , from Mrs Baldilocks, Portsmouth 4 Toon 1 !! Just smacked mesel with a lump hammer trying to shock the clutch-nut off (uncle Albert's false teeth wouldn't hold the clutch basket still ). Off to Steve's first thing tomorrow to use the ratchet gun. Hope his neighbours like the sound of his compressor...it's a whopper! Wayne
November 4, 200719 yr any success with the clutch basket Wayne ? gear is all here to do it if your stuck Clutch Basket 1 Wayne 0 ! Primary gear is quite hard to remove as well
November 6, 200719 yr Author any success with the clutch basket Wayne ?gear is all here to do it if your stuck Clutch Basket 1 Wayne 0 ! Primary gear is quite hard to remove as well Cheers Glen, Clutch basket is off (care of Steve),I am taking my time on this..... but not so long that I have forgotten how it all goes back Re-start dismantling tonight...I'm guessing that I can hold the flywheel to undo the primary gear nut or will I twist the crank?? Edited November 6, 200719 yr by HAM2
November 6, 200719 yr so why didnt you get the flwheel nut and the primary gear nut undone at Steves while you were at it ? Ive never tried holding the flywheel mate
