Cota 348 Hydrobag
zulu
Hi there zulu,
I have a Cota 348 with hydrabag shocks. I stripped these right down, they are rebuildable if you can get hold of the correct seals. Bag is split on one of them so will probably seal off the bag area and use without the bag, or just buy new ones!
Bye, PeterB.
Cheers guys - After a tin of "penetrant spray" some heat and home made spring compressor (Tie-Down Straps) all is good and a rebuild is in progress, bags look good. Any idea how much fork oil to add ? I might have to go the `trial and error` route. Many thanks once again.
