Transmision Oil Drainage Plug ? & Top Up Plug ?
txt270gasgas
There seems to be more than one plug underneath the sump guard which one should i use to drain the gear oil, the one nearest to the rear wheel or the one nearest to the front wheel. the bike is 98 TXT
Cheers
Jos
Edited by txt270gasgas
Oil fill is on the clutch case, below the kickstart. Refill 700ml 10 weight mineral or an ATF rated to Dexron III.
The other drain plug, closer to the front wheel is for draining water from the crankcase, should you ever drown your bike.
Bye, PeterB.
For filling, I use an old Castrol oil bottle with a plastic tube extension, measure out the quantity and fill into the Castrol bottle then squeeze it in.
Bit too far to go to buy me a drink, but thanks anyway.
Bye, PeterB.
