March 9, 200818 yr Hey everyone my clutch lever on my 02 rev that i just bought takes a while to enguage and rebound after it is pulled in. Help me what could be wrong
March 10, 200818 yr If you seriously want help I suggest you have another go at explaining what the problem is.
March 10, 200818 yr Author When the clutch is pulled in it goes in but when you let off it takes about 5-10secs befor the lever gets hard again and the clutch also takes a few seconds in enguage
March 12, 200818 yr Could it be something as simple as the lever pivot bolt being too tight? If not then yeah, bleed the clutch and if that doesn't help, take a close look at the plates.
