Techno flywheel torque setting?
davieboy
I have fitted a new stator to my 1999 Techno 200 and seems to be running fine now after a bit of trial and error with the ignition timing.I have retarded the timing about 2mm from the centre of the screws and it seems to be running ok.I will need to try a test run.Does anyone know the torque setting for the flywheel?I have it at about 70 Newton metres at the moment safely but do not want to go any tighter as I don't want to strip the threads.
