Top End Bearing
Hi everyone, could anybody tell me the bearing number for the top end bearing on a 2001 txt 280 and also if i replace this bearing will i also have to replace the gudgeon pin ?
Cheers in advance for any info.
I think that number is M01411100. You don't always need to replace the grudgeon pin, but it's a good idea. It's probably had 7 years of use and it is an inside bearing surface. It will extend the life of the bearing if replaced.
Jon
