Torque Settings
dickielumpkin
Help Please!
Does anyone know where the torque settings are listed for all the engine bolts, screws etc. for a 2002 250 (Sherco O2) ?
I am sure this must have been asked before but I just can't seem to find them.
Many Thanks!!!
Here hopefully------Torque talk
A couple of notes as I did eventually manage to do a bit of follow up testing on mine. The main case bolts(6mm) did seem to have a factory torque of around 75in/lb to break loose and re torque.
I do think the dry/ wet thread limits should be maintained as it seems to me that some are very close to the limits. Ant that is also why I recommend marking the big stuff before disassembly, sso you can go back without hastle. If you strip one of these , you are pretty much screwed! ;)
