May 17, 200818 yr I just picked up a used 2006 4RT but it didn't come with a manual. Can someone email me the pdf ( hadron@tjee.org ) or message me with a link where I can download it? Beyond general information, I'd like to change the oil in the forks - so if anyone can tell me what the stock weight is for the front forks and any tips or tidbits on how I should go about changing the oil I'd be most appreciative. Although I've fiddled with the rebound and compression adjuster the forks just aren't as lively as they should be (compared to a back to back with another 4RT). Thanks. --Tim
May 18, 200818 yr That'll be me as I said you won't need it as they are pretty reliable, but quite a comprehensive manual................
May 18, 200818 yr i will second that, the bikes are so reliable you wont really use it except if your new to montesa 4rt changing oil and thats about it. Set of pads and a new C and S occasionally for which you dont need a manual for this and your laughin. JOB DONE which leaves you to enjoy your ridin. Good Times.
