erixon Posted August 28, 2004 Share Posted August 28, 2004 I'm about to change my transmission oil....in the service manual it says: The oil level must be between the minimum and maximum indicators??? I can't see any indicators in the window??? I't also says that the system holds 550cc of oil.....should i just drain the oil and fill up 550cc of new oil ? Quote Link to comment Share on other sites More sharing options...
erixon Posted August 28, 2004 Author Share Posted August 28, 2004 My bike is a pro 280 -03 Quote Link to comment Share on other sites More sharing options...
jtt Posted August 28, 2004 Share Posted August 28, 2004 Ignore the indicator window, it's only good to tell you if it's empty. I find 450ml is fine for a normal oil change. If you were doing a tear down and complete cleaning 550ml might work fine, but I find it blows off under normal oil change conditions. Quote Link to comment Share on other sites More sharing options...
colly Posted August 29, 2004 Share Posted August 29, 2004 fill to the level where you pour it in Quote Link to comment Share on other sites More sharing options...
