June 30, 200818 yr On a Amal Carb if you start the bike and it run for about 1min on tick over and it then stops, what would be the problem? If i tickle it again it will start, it's as if the fuel reservoir is emptying, is the float jamming or is there a hole blocked somewhere
July 1, 200818 yr Prolly float. Any gas in the float? If not check float level. Anyways, that would be my guess.
