July 27, 200818 yr Hello mate, I repaired my tank with Arildite. depends where the crack is and how big it is.Mine was where the kickstart sits,tryed petrol patch but after a while it started to leak again,hope this helps.
July 28, 200818 yr There is a product called Plastex that works a treat. It comes in different colours, and the blue is not a bad match for Scorpa blue. it can be sanded and painted when dry. Their website is: Plastex You can also get it professionally plastic welded. The base material is a type of Nylon. Paul The Hell Team.
July 29, 200818 yr There is a two part plastic bonding developed for bumpers, mudguards and fairings, its also suitable for fuels. Its called B2. Mix it 50/50 and it goes of to the touch in about twenty minutes, leave it for 24hrs and you can sand and paint it. Its realy tough and normally prodces a fix stronger than the original nylon or plastics, sadly only in black. The only other solution I have used in the past and found it worked realy well on a fuel tank was fibreglass. More work and preparation but its pretty permanent. Edited July 29, 200818 yr by renegade
July 31, 200818 yr Author There is a two part plastic bonding developed for bumpers, mudguards and fairings, its also suitable for fuels. Its called B2. Mix it 50/50 and it goes of to the touch in about twenty minutes, leave it for 24hrs and you can sand and paint it. Its realy tough and normally prodces a fix stronger than the original nylon or plastics, sadly only in black.The only other solution I have used in the past and found it worked realy well on a fuel tank was fibreglass. More work and preparation but its pretty permanent. Cheers,where do you get the B2?
August 4, 200818 yr Sorry for the delay in my reply, I've been away for a few days. Its manufactured and sold under the following companies products JB Weld http://www.jbweld.net/products/uses.php Part No. 8277 its called waterweld on this site you can even use it in a wet fuel tank. I purchased mine through Silverstone factors at Silverstone. But you can buy it online. regards renegade Edited August 4, 200818 yr by renegade
September 2, 200817 yr Author Hi,thanks for all your suggestions,finally sorted the tank!!!!!!!!!!,used PERMABOND,FLEXON F246,a toughened acrylic adhesive.
