August 30, 200818 yr Hello its been a while since I was last on here, according to when I logged in it was April last year After a 2 year break I
August 30, 200818 yr Glenn, sometimes tightening a bolt very slightly can break the seal holding it fast, worth a go, I have used pro gas anti seize as well which is a really good product for stuck bolts/threads
August 30, 200818 yr Any way you can get a nut splitter on the bugger mate Edited August 30, 200818 yr by The Addict
September 5, 200818 yr Author I eventually got it out. I soaked it for a few days with parrafin, its really good a penitrating (excuse me sir), used in industry for finding holes that water can't get through, it leaves an oil residue, its also used for cooling/lubricating aluminium when cutting. Also i had some in the garage and couldn't be bothered to go and buy anything. Thanks for the surgestions Cheers Glenn
September 11, 200818 yr Bicycles were introduced in the 19th century and now number about one billion worldwide.The bicycle, cycle, or bike is a pedal-driven, human-powered vehicle with two wheels attached to a frame, one behind the other.They are the principal means of transportation in many regions. James Auto Auctions
