September 10, 200818 yr 250 Beamish needs re boring, do I stay at 250 or remove the insert liner and go back to the original manufactured size of 325. If so what else is needed to be done. What difference will be felt if I switch to the 325? Anybody got any other tips to make a Beamish as competitive as possible?
September 10, 200818 yr make sure you can get a piston if you go 325 , there were very difficult to get a few years ago.
September 11, 200818 yr 250 Beamish needs re boring, do I stay at 250 or remove the insert liner and go back to the original manufactured size of 325. If so what else is needed to be done.What difference will be felt if I switch to the 325? Anybody got any other tips to make a Beamish as competitive as possible? Put it back to standard. 325 pistons are available, look on the Beamish Club website. I would suggest that fairly tall handlebars are used (unless you are very short) as the standard footrests are rather high and lowish bars tend to make you lean too far forwards.
September 12, 200818 yr Author I have seen the 325 pistons on beamish owners club web size, does the head need any mods if a bigger piston is installed. Any idea what oversize piston would be required after the 250 sleeve is removed. Ta
September 12, 200818 yr You need to speak to Nigel Birkett for a definitive answer. I was thinking of doing the same with a 250 I once had and I'm sure I was told the head would need work, strange I thought seeing as they were built as 325 and sleeved down to 250, so maybe the 250 was fitted with a different head. The 250 should go well enough if you take off the big crank weight on the clutch side which will allow the motor to spin up quicker, should you feel the 325 conversion is too much agro.
December 16, 200817 yr Don't go to 325! There was a very good reason that Beamish took the standard 325 and sleeved it down to a 250, the 325 is too much of a handful unless you are 18+ stone or have a sidecar. 250 pistons are easy to come by, all available 325 pistons were designed for another make of bike. The head on your 250 was skimmed when the barrel was sleeved but no-one knows by howw much so it would be trial and error to get the compression ratio back right. 250 pistons are everywhere and the bike will perform much smoother as a 250. 5.5" bars or 6.5" if you can get them and move the pegs if you don't mind spoiling the chrome for the sake of performance.
