higgypop Posted September 13, 2008 Share Posted September 13, 2008 has anyone had any problems with the timing chain tensioner chain sometimes slaps when rev and tickover, I have checked the timing chain tensioner it seems to operate fine ! Quote Link to comment Share on other sites More sharing options...
essex rider Posted September 13, 2008 Share Posted September 13, 2008 I noticed this today, only when the bike was cold and on very low tickover. Dont know if it means anything but it stops once the engines warm or if i fiddle with tickover speed. Quote Link to comment Share on other sites More sharing options...
sirhc Posted September 14, 2008 Share Posted September 14, 2008 (edited) I think what you are hearing is the automatic compression release. I've heard it on other 4t's (non trials). At very low idle or tick over the cam isn't going fast enough to full disengage it. I think my 3.2 did it too, but I really can't remember. Edited September 14, 2008 by sirhc Quote Link to comment Share on other sites More sharing options...
higgypop Posted September 15, 2008 Author Share Posted September 15, 2008 thankyou for your feed back Quote Link to comment Share on other sites More sharing options...
higgypop Posted September 29, 2008 Author Share Posted September 29, 2008 hi I retensioned the timing chain spring then reasembled the parts to the chain tensioner which gave it a stronger tension on the chain slides thus quietening any chain noise runs great now superb, infact I have had 2 montesa 4rts and it grips better than them and is easier to do trick riding because it feels alot lighter I would recommend these bikes I have owned all the other marquees except beta and it is superb Quote Link to comment Share on other sites More sharing options...
shercorider Posted October 2, 2008 Share Posted October 2, 2008 I replaced the timingchaintensioner on my 3,2 4T the other day and it fixed the problem. It now runs without any noise from the chain. Now there Quote Link to comment Share on other sites More sharing options...
higgypop Posted October 2, 2008 Author Share Posted October 2, 2008 try a slightly thicker oil you will be suprised with the difference mine is very quiet now hope this helps Quote Link to comment Share on other sites More sharing options...
shercorider Posted October 7, 2008 Share Posted October 7, 2008 try a slightly thicker oil you will be suprised with the difference mine is very quiet now hope this helps Any suggestions on what oil to use in a 3,2 4T? Quote Link to comment Share on other sites More sharing options...
higgypop Posted October 8, 2008 Author Share Posted October 8, 2008 (edited) I use Mobile 1, racing 4T fully synthetic 10w-40 4 cycle motorcycle oil. hope this helps also have you replaced the valve shims yet mark Edited October 8, 2008 by higgypop Quote Link to comment Share on other sites More sharing options...
kingfisher Posted October 22, 2008 Share Posted October 22, 2008 Higgy How did you retensioned the timing chain spring, or did you replace it with a new spring Quote Link to comment Share on other sites More sharing options...
higgypop Posted October 24, 2008 Author Share Posted October 24, 2008 hi in response to how I got more tension on the timing chain tensioner 1, I first took it of then I remove the circlip that holds it together at this point the tensioner arm will pop out. 2, there is a bolt on the other end of the tensioner you need to take it off, you will now able to put tension on the spring with a small spade screw driver, while you have still got tension reasemble the tensioner arm by screwing back on, holding the parts together with the tension arm full retracted put the circlip back on. 3, If you have done the above correctly it will have more tension power than before you disasembled it I hope this helps, it made my engine alot quieter I hope this helps let me know how you go on Quote Link to comment Share on other sites More sharing options...
kingfisher Posted October 26, 2008 Share Posted October 26, 2008 i tock the tensioner apart this morning and found that the spring was broken, i will take it back to the dealer and see what he says thanks for your help Quote Link to comment Share on other sites More sharing options...
