November 11, 200818 yr Hello Redrocket, TY250nl is absolutely correct the clurtch cover is from a 1973 KX450, a guy in my club has a KT with the KX clutch cover fitted, it fits directly onto the KT engine after the posilube pump is removed. The KX450 clutch cover makes the bike look trick and is narrower at the front section several people fitted them after they removed the oil pump. The red bike that you pictured was up for sale some time ago a welsh man claimed that it was an ex works bike, but it is not, as it has the window in the side panel to view the oil tank that was fitted to the standard bike (works bikes had bolt on panels or a seat tank unit) and a throttle cable that splits to the posilube pump plus other standard production features. Regards
November 11, 200818 yr Still not convinced - look at a picture of a KX450 and compare the size of the clutch cover to the cover on the red bike. The KX cover is much bigger.
November 11, 200818 yr It was my red kt and it was a real ex-works bike!!!!!! and the very first works bikes were red not green it was verified as a works bike before i bought it..! was in a bad state when i got it, but it came nice in the end. I sold it to someone from down south!!
