November 30, 200817 yr I am new to the sport and wondered what everyone used to mix 2-stroke up ? I have used just the usual green plastic jerry can but wondered if there is a neater solution ? Mark
November 30, 200817 yr I'm newish to the Sport too, So i use Ipone Strawberry two stroke oil which comes with a built in measurer. I just squeeze the required amount up the tube on the bottle ( 80-1 ) then just add to one full Green plastic Petrol can ( 5 Liters ), Easy!!!!!!!!!!!
December 1, 200817 yr I was recommended 50:1 mix by my dealer. 100ml to every 5 litres, Motul 710. I have always used the green plastic jerry cans, they do the job nicely and i've had no need for the big metal ones. plus it keeps costs down!!
December 1, 200817 yr I am new to the sport and wondered what everyone used to mix 2-stroke up ?I have used just the usual green plastic jerry can but wondered if there is a neater solution ? Mark I use a thing called accurmix or something like that, you can find them on fleebay. it is basicly a plastic can with 2 compartments, 1 for oil and the other petrol with numbered markings on both for all mixes, 50:1 25 etc etc and all you do is turn it upside down to mix it all. really easy to use even i mange it and i think they prob mix 5-6 litres at a time
