2008 Sherco 290 Rear Shock
Hi
My 08 290 rear shock seems to be bottoming out very quick? anyone recomend anything?
Cheers
It is usually neccessary to adjust the spring after it settles.
I run mine to where the rear will settle about 20-30mm under its own weight(bike only, no rider).
This could require 3 or more turns of the adjuster ring. :guinness:
there is also a dampening adjustment located from the left side just past the chain tensioner, start it at 5-6 clicks out or counter clockwise. turning it in will increase dampening.
cheers
cheers
I thought that was only for rebound dampening??
Best of balance.
Neo
Best of balance.
Neo
i had felt that it was both rebound and compression while fine tuning mine but i confirmed it with ryan young and it is both
cheers
