kickstart101 Posted January 11, 2009 Share Posted January 11, 2009 Hi guys wondered if you can help, having trouble with my Gas Gas TXT 04, could be as a result of the cold weather, not sure? Sometimes difficult to start, but when it starts ok it runs fine for a couple of minutes then struggles to run, have to hold the throttle open to stop it stalling. Turning the tick over up doesn Quote Link to comment Share on other sites More sharing options...
hoggle Posted January 11, 2009 Share Posted January 11, 2009 The same sort of question was raised this week on another thread. I also have the same problem when it's cold with the Carb icing up, i start the Bike then run it for a wee while then turn it off then let it sit for a couple of minutes that lets the Heat through from the Engine into the Carb. Start it up again then all should be well ! Quote Link to comment Share on other sites More sharing options...
kickstart101 Posted January 11, 2009 Author Share Posted January 11, 2009 Tried this and it works spot on mate, cheers. Quote Link to comment Share on other sites More sharing options...
