Suspension Travel And Sag Settings
Can anyone give me advice on setting the sag on a 06 rev3 270? I'm 17 stone so a bit heavier than your average trials guy! All advice welcome!
Cheer.
Without a rider the bike should sag a little - 5mm is good. You can turn up spring tension only so far, too much and you are asking a light spring to do too much work...if you are heavy build you'll likely need a heavier rear spring
With a rider the bike should sag eavenly. Both ends sould sag between 25-33% of available travel. As a guide ..... 25% if you like a lively suspension action, 33% if you prefer a more planted/dead feel to the bike.
Cheers mate. I'l try it and see.
