Engine Bogging Down
peteostatic
Hi all,
New on here, would appreciate some help with a problem on my 06 250 Rev 3.
When travelling between sections, in higher gears, when the engine is under load(up hills) it has a tendancy to bog down, almost as if the ignition has cut out. Dropping a gear and getting the revs back up cures it, or slipping the clutch. Not normally a problem but it happened on a hill climb section recently, which wasn't very helpful!
Recent stator plate fit and new cylinder/piston kit too.
Thought it might be fuel starvation, I would assume the jetting is standard. Any one experience similar?
