January 24, 200917 yr hi there is there anyone who could tell me how much gear oil i should put in my txt 280 ive drained about 500ml out of it and wasnt sure if there should be more or less. thanks alot if anyone can help.
January 24, 200917 yr Taken as an extract from the service book. Hope it helps Maintenance summary Cooling liquid -30
January 25, 200917 yr hi there is there anyone who could tell me how much gear oil i should put in my txt 280 ive drained about 500ml out of it and wasnt sure if there should be more or less. thanks alot if anyone can help. You might think about running about 650-700cc's of a light-weight trans fluid in cooler weather, say 5W-30 or Dexron ATF in the "Edition" type engine. Jon
February 3, 200917 yr You can check if you loaded the correct amount by looking in the little round window on the right side of the tranny. It should be about half way up the window. In my '02 Edition, I've been using the cheapest ATF I can find at Walmart, and it works just fine. I change it 2 or 3 times per year, and clean off the drain plug magnet while I'm at it. Dave
