February 4, 200917 yr Hi guys just wondering if any of you have had the same problem. I Got my stator coil re-wound put the bike back together with correct timing markings, it took ages to start when i got it started it gave kick back i then put it into gear and the bike was runing backwards so cheked woodruff key and timing again (all good). Tryed it again but no luck i even tryed retaring the timing a little but still the same. Dont have a clue what else to do!! Any help would be very nice Thanks Jorge.
February 4, 200917 yr Jorge, take your handlebars off and mount them on the rear mudguard, you'll be going the right way then with the added bonus of the kickstart being the right side of the bike Think youve got your timing way out mate, did the stator go back on in the correct position?
February 4, 200917 yr Gday all, Hmmmm interesting - it sounds as your source coil may be connected backwards. Have you checked timing with a light? Mark TDC on the flywheel and get your mate to kick it over while you have a look and see whats going on. It should happen a few degrees before TDC ( around 10 mm before your TDC mark) Let me know what you find. Cheers, Stork.
February 5, 200917 yr Jorge, Is the coil symetrical and do you have long enough wires to flip the coil over? As Stork said this will change the ignition timing and you can verify it with a timing light. Let us know what you find out. Frank
February 6, 200917 yr Author Hi and thanks i have sent the coil back to the guy he got the ohms wrong im sure its 400-450ohms he put 300ohm dont know if this has any thing to do with it but he is going to give me a full re-coil for FREE! thank you all very much for your help
February 6, 200917 yr Author Jorge,Is the coil symetrical and do you have long enough wires to flip the coil over? As Stork said this will change the ignition timing and you can verify it with a timing light. Let us know what you find out. Frank Tryed to flip the coil over but there is only one way it goes together and i had marked the plate before removing.
February 11, 200917 yr Author Hi guys cheers for all your trials help and support but turns out it was my stator coil something to do with the charge and source coil now behind the bars and going forward from now on (((( hopefully! )))). Im happy to help any one with the same problem!! Cheers Jorge
