February 9, 200917 yr My D14 still has the original rotary clutch actuator that is about worn out , with an 8 spring 4 plate clutch it's starting to be an issue .I've seen some custom built lever type , but no good pictures , I'm open for any ideas . This is about the last area that needs to be improved then I can't blame the bike for all those points cheers , Bruce
February 9, 200917 yr That Helical Action actuator should be available fairly easily. There isn't an awful lot of room to engineer as elegant a solution. Those things are quite compact. Why use the clutch Wayne....
